Nice Trap
Originally Posted By: jpope
New install. . .
![](upload://jCxok2BOxQPhQw1UIiVpyui4Mpf.jpeg)
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: jstewart1
Looking at that cast iron pipe brings back bad memories of when I was serving my plumbers apprenticeship. Oakum and lead. The municipality I worked in demanded extra heavy cast iron. Cut the pipe with a hammer and chisel. Those were the bad old days. icon_sad.gif
Originally Posted By: dhartke
Jerry
Referring to the oakum and lead, was the lead ever intended to seal or was it's job only to stabilize the joint and hold the oakum in place?
Another question. I've seen some lead joints that have what appears to be a waxy flux paste around the leaded area and on others the lead is clean and dry. Was a flux used some or all of the time?
David,
The lead was used to keep the okum in place and stiffen the jpint.
Its been a long time since I worked with lead and okum, but If I remember right the okum was permeated with a waxy substance. No flux was used
As a side, when I took my jouneymans test you had to cut a y into a 1 1/2
inch lead pipe and wipe the joint with molten lead.
Jerry
Thanks Jerry.
Working with lead is almost a lost art due to its unfriendly nature with the environment and people. 34 years ago I took my 66 Impala to have some body rust repaired around the back glass. The old bodyman leaded it in without removing the glass. Skill.
