Noted this on an inspection today; using 2X4’s for the ridge board support, but they are notched out more than half way, which does not seem OK to me. Anyone have any thoughts?
Not a problem.
Thanks Scott.
What’s under those supports? Bearing wall? I think the notch is fine but what about the other end? I don’t like how it’s resting on a flat 2x4 spanning three joist. Those two in the background look way out of plumb. I do not think it is going anywhere, looks like it’s been there awhile.
Yes, bearing wall underneath. I noted the two that are out of plumb in the report. 1973 house.
Living in the Northeast, when building, I add the vertical 2x support under the ridge for added snow load support, although it may not be necessary.
What was the roof’s slope?
Looks like a 3 in 12 and understandable to support the ridge. Those are hefty rafters.
Exactly that’s real wood.
needs collar ties
