but they DO leak, seep and they DO have EXISTING defects on exterior of foundation wall as in these short videos, and they pretty often have some efflorescence of discolorment on inside basement wall but as always do what YOU like lollll
DETERMINE, identify each homeowners problem (s),
2 different areas this lady was getting water in where the bottom of the foundation wall meets the basement floor… chimney area and small part of front wall
Here’s why the front leaked… Grosse Pointe Farms
and
Water FIRST got into hollow blocks through those exterior openings, the water stayed INSIDE the cores of blocks and then it dropped down through the lower blocks where it eventually (gravity eh) wound up in the bottom blocks and then came out onto basement floor
here’s short video of inside basement
here were most of the problems with chimney area, where the water was FIRST getting in the hollow blocks
And before i took the job, before i take ANY job… doing a water test for free (this is going to change) to correctly 'n honestly DETERMINE how-where the water is first-entering
How much is it worth to you Mr and Mrs homeowner to have your actual problem (s) honestly determned BEFORE you spend ONE cent? The inside system people told homeowner she needed an interior MORON scam system that would have cost MUCH more money and basement would still have water entering through the exterior openings you saw in videos! lolll i mean hello!
Many hire the wrong person/company for their leaky basements, YES they do, see it all the time throughout 40 years, hence these videos. Honest experienced contractors are often overlooked, undervauled and rarely appreciated in todays world.
When was the last time anyone saw an INT system knothead do a water test that would have correctly identified homeowners problem, for free? NEVER.
What about the INT system morons who never tell homeowners who have a blockage in lateral line or are just getting water in through, around, under a basement window, they do NOT inform the homeowners they just need a plumber or new basement window or just need to seal the grade/brick ledge that has openings just below ground level, like this homeowner…
Everdry told them they needed to spend $35,000 on an INT system… really?
HERE were their problems were the water FIRST entered, fixed for $350, NOT a drop of water in since
HERE was the water test i did, for free lol, to show them, to prove to homeowners where the water was FIRST getting in
Everdry… $35,000 EH? THEY HAD HOMEOWNERS SIGN CONTRACT, RUSH RUSH RUSH, THEN HOMEOWNERS HAD 3 DAYS TO FIND ME, how much am i really worth to ya? yeah
