Has anyone else seen this Onix Tubing. I believe it is feeding a toe kick space heater and from what I was able to look up about it is ok to be used for Heating supply and return lines. I did a quick search and did not see anything on it.
Yeah it is a Watts product and with the info I found online it appears to be pretty good as it can be used to driveway or walkway heating in snow melting and also for a radiant flooring heat system. I guess all the toe kick heaters i have seen it was all done under the cabinet so i have never seen it exposed like this. At first looked alot like a washing machine hose and was very concerned at first!
Sorry I meant I did a quick search on the forum on it as I did find the link posted. I was just wondering if anyone had anything to look out for or bad with this product.
