P-Trap Required With Grease Trap?
Originally Posted By: fduemig
http://www.nachi.org/bbsystem/usrimages/D/DSC001352.JPG ]
Thanks,
Fred
Fred Duemig
Originally Posted By: mcyr
Hi. Fred;
Hope you are doing fine, and work is in abundance.
I am not a plumber, but a Commercial Builder, and think that a pea trap is not required with the use of this grease trap, for I believe it is creating the trap required. I might be wrong, but sure someone will respond and comment to my comment.
Hope this helps.
P. S. I believe someone will quote a code on this issue and put you at ease.
Marcel
Originally Posted By: jpope
I’m not sure that a grease trap would comply with the requirements of P3201.
Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
Originally Posted By: wcottrell
Most applications on the commercial side have the sink or sinks without p traps dumping into a floor sink which is trapped prior to the grease trap.
Regards Bill
Just what I wanted to say. Thank you.
Marcel
Thanks for the replies. This setup does not have any trap prior to the grease trap. Also, the grease trap is leaking. There is a wad of grease at the rear of the tank.
Fred
Fred Duemig
http://www.nachi.org/bbsystem/usrimages/G/Grease_Trap.jpg ]
[ Image: http://www.nachi.org/bbsystem/usrimages/G/Grease_Trap_Multi_Story.jpg ]
http://www.pdionline.org/publications.htm [/url]
Fred Duemig
