because it says so on the side on the supply line Tom
it actually just says IP and has some numbers
Whatever the pipe is, it is not the PB which had such a high failure rate. And as mentioned, not all PB failed.
In my report I mention PB has a higher failure rate and recommend a plumber evaluate for a risk assessment.
Does “IP” correlate to PB? I searched and could not find it.
And as simple as this.
I couldn’t find anything on that either.
recommend replace with braided lines
why replace?
To be honest i haven’t had one of those supply lines in my hands for years, even when i was working it was not something I would reach for unless it was the last thing available. You have to wonder though why would someone put supply lines behind a tub/shower valve ?
The black mechanical DWV vent is not atmospheric type or a Studor valve.
Risers PVC.
The tub overflow port has been abandoned.
