PDI Inspections
Just curious if any Ontario home inspectors do Pre-Delivery Inspections for builders ? Is this mandated form only an Ontario requirement for builders or is it all over in Canada ?
James,we do PDI inspections,but not for the builder normally ,but for the purchaser,very few builders want us involved in the trans action,but I believe we can play an inportant role for the buyer.
Ontario builders typically have their own inspectors do pdi’s, they are mostly cosmetic, they rely on the municipal inspections during the building process for structural, code etc. In high volume areas only a percentage of homes actually get full inspections as municipal inspectors are apparently stretched for time.
You can check out the pdi’s here:
http://www.tarion.com/HOME/New+Home+Buyers/Your+Pre-Delivery+Inspection/
Isn’t there a checklist they are required to go through for these PDIs ? These are not supposed to be just cosmetic type of inspections.
This is about it:
http://www.tarion.com/NR/rdonlyres/202DDFC9-97B7-41D1-B856-39A3D3AD760A/0/Feb2009PDIForm.pdf
This is more of the checklist I was referring to:
http://www.tarion.com/HOME/New+Home+Buyers/Your+Pre-Delivery+Inspection/PDIChecklist.htm
IS this the form http://www.tarion.com/NR/rdonlyres/8FEE560B-D84F-4FB2-BD80-E8D6ED6D0584/0/CPGDoc_v2.pdf
Wow…not that’s a form to fill out !!! 268 pages worth !!!
My god! This is not a check list.
It is 268 pages of exceptions and excuses for the builder to escape any responsibility.
There is no protection here for the buyer.
There is no way I would buy a house under these conditions.
This was sanctioned by the governement. The same government that cahpi wants to write rules for HI’s.
A house that meets these standards would never make it past a proper home inspection.
Now I know why many new home inspections I do end up in arbitration.
Brian A. MacNeish just loves to talk about the weasel clause I and others have in our contracts .
Most of what is used was recommended by a lawyer or Insurance company .
I do hope he down loads and prints this and see what a Tarion has to confuse all ](http://www.tarion.com/HOME/New+Home+Buyers/Your+Pre-Delivery+Inspection/PDIChecklist.htm)http://www.tarion.com/HOME/New+Home+Builders/Policies+and+Guidelines/ConstructionPerformanceGuidelines.htm
Go down to You can also download the complete Second Edition of the Construction Performance Guidelines
http://www.tarion.com/NR/rdonlyres/8C656ACC-0DB3-41E1-A19F-37EAEE256A2B/0/pub_acrobat.gif
(2 MB). Please note, download times for this file using a dial-up connection may exceed 10 mins.
Vern:
So none of this goes on in Alberta??
Here’s a performance standard from the Alberta New Home Warranty Corporation:
Condition: Finished floor above grade is out of level.
**Acceptable Performance **Condition: Within a room, floors shall appear level when viewed from a normal viewing position. Where a floor is sloped, a maximum ratio of 25 mm over 3 meters (1 inch in 10 feet) applies, when measured between the opposite walls or defined limits of the room area.
Warranty: One-Year Workmanship and Materials.
Action: Floors in rooms sloped greater than the acceptable performance conditions shall be repaired.
Remarks: Refer to: Section 9. 27 Finished flooring is uneven.
And… the Alberta New Home Warranty Program is run by the builders! Sorta like having the foxes guard the chicken coop, isn’t it???
Which is worse? Government or the foxes “protecting” the interests of consumers?
Note: There are 3 other new home warranty companies in Alberta. I almost dealt with one that also offers warranties here in NS but after very short consideration decided I’d be better off having a nice day doing something else!!
The document referenced is from Tarion in Ontario. Are you doing inspections there?
I guess I’m in your head all the time now, Roy. PITY!!
Yes, I have seen documents like this. I have worked for and against the Atlantic Home Warranty Program in the last 7-8 years.
The last time was about 25 months ago…the house showed up in a local scandal rag…FRANK Magazine (Motto: Frank by name; frank by nature!). My client homeowner ended up getting the maximum $50,000 structural payout from the program for structural rot in his 8 month old $800,000 home. There was a 7 month arson investigation of the house starting about 18 months ago. Very interesting!!!
I wonder why two things stand out in most of your post’s
One How Great Brian is
and
Two How bad NACHI is
Ah! Right on Time. I was wondering when I’d feel your presence again, my biggest fan…er…stalker.
Can you add anything to the topic here? Hell, I hadn’t even posted anything in this thread when you dragged my name in and used it in vain!!
Are we having fun yet? Remember the past…
12/31/09 3:21 PM rcooke](http://www.nachi.org/forum/users/rcooke/)
We need More like Brian who tell it like it is ,
He also has the knowledge to go with his post,s”
You did this to me!!
[size=1]
[size=2]SO SAD how the truth upsets Brian ,
Yes I did say on (:12/31/09 :slight_smile: it is not my fault you have lowered your self to only Praise Brian and Slam NACHI…
Sorry to see you lost yesterdays Inspection Hope they booked for a later day… Roy
[/size][/size]
It was a holiday, remember…and I needed the break…working the next 4 days straight though! Got the winter’s wood piles under control and threw in a few weeks supply…great for the soul…especially the free wood from an arborist!!
PS…Send me a GPS location unit for my vehicle so you can see where I am in an instant and won’t have to worry about me!!!
Yes I did say on (:12/31/09 :smile: it is not my fault you have lowered your self to only Praise Brian and Slam NACHI…
So glad he has our home to come into and praise him self ,
[FONT=Times New Roman][size=3] Your Bragging is constant how well you do and how you get so many inspections . [/size][/FONT]
[FONT=Times New Roman][size=3]I wonder why you would be adding to the pollution with your free wood . [/size][/FONT]
[FONT=Times New Roman][size=3]I see more places continually ban the burning of wood do to the pollution . [/size][/FONT]
[FONT=Times New Roman][size=3]I wonder how you get the time to split and stack wood with all your business .
I think you are teaseling us with all your inspections you say you get .
I wonder where you find the time to sit on the NACHI site and complain all the time
[/size][/FONT]
I went to
http://www.nca-anc.com/index.php?option=com_dbquery&Itemid=54&task=ExecuteQuery&qid=2046&previousTask=PrepareQuery
to confirm Brain saying he is a NCA holder and it does not confirm that I wonder did he get scammed and is not approved .
Now that would be a shame if Brian was conned by some one . http://www.nca-anc.com/ does not list him
---------------------------------------------------------------------------------------------------------------------------------------------- [FONT=Times New Roman][size=3]
Home
http://www.nca-anc.com/images/M_images/arrow.png
Industry
National Certificate Holder Verification
Search for a National Certificate Holder
](javascript:void window.open(‘http://www.nca-anc.com/index2.php?option=com_dbquery&Itemid=54&task=PrepareQuery&qid=2046&previousTask=PrepareQuery’, ‘win2’, ‘status=no,toolbar=no,scrollbars=yes,titlebar=no,menubar=no,resizable=yes,width=640,height=480,directories=no,location=no’):wink:
[FONT=Arial][size=2]
Version
Français
Putting your clients in touch with nationally certified home inspection professionals reinforces your relationship with your clients. It enhances your professional image and lends more protection for you. The client will feel more confident with the condition of the property, and the quality of your advice. Verify a national certificate holder and recommend them to inspect your clients next home; you are hiring a professional with proven ability, experience and impartiality.
To verify a National Certificate Holder inspector, enter the inspector’s full name.
Our Verification Database will return only exact matches. You must enter both a first name and last name.
First Name* Normal Text
Last Name* Normal Text
/* this DIV is the semi-transparent white background of each menu. the -moz-opacity is a proprietary way to get transparency in mozilla, the filter is for IE/windows 5.0+. // we set the background color in script because ie mac does not use it; that browser only uses a semi-transparent white PNG that the spacer gif inside this DIV is replaced by /.transMenu .background { position:absolute; left:0px; top:0px; z-index:1; -moz-opacity:1; filter:alpha(opacity=100);}/ same concept as .background, but this is the sliver of shadow on the right of the menu. It’s left, height, and background are set by script. In IE5/mac, it uses a PNG /.transMenu .shadowRight { position:absolute; z-index:3; top:3px; width:2px; -moz-opacity:0.4; filter:alpha(opacity=40);}/ same concept as .background, but this is the sliver of shadow on the bottom of the menu. It’s top, width, and background are set by script. In IE5/mac, it uses a PNG */.transMenu .shadowBottom { position:absolute; z-index:1; left:3px; height:2px; -moz-opacity:0.4; filter:alpha(opacity=40);}Home|About National Certification|Industry|Home Inspectors
http://www.nca-anc.com/modules/mod_d4j_transmenu/img/x.gif
Contact Us
Why Use a National Certificate Holder
Links
Announcement
Inspector Standards
Home
Industry
](javascript:void window.open(‘http://www.nca-anc.com/index2.php?option=com_dbquery&Itemid=54&task=ExecuteQuery&qid=2046&previousTask=ExecuteQuery’, ‘win2’, ‘status=no,toolbar=no,scrollbars=yes,titlebar=no,menubar=no,resizable=yes,width=640,height=480,directories=no,location=no’):wink:
The name entered is not a match to any national certificate holders currently contained in our database. Please check the spelling and re-enter the name or visit the CAHPI web site to find an inspector in your area.
Version
Français
[/size][/FONT][/FONT][/size]
[FONT=Arial][size=2]I went to
](http://www.nca-anc.com/index.php?option=com_dbquery&Itemid=54&task=ExecuteQuery&qid=2046&previousTask=PrepareQuery)
to confirm Marcel Gratton saying he is a NCA holder and it does not confirm that I wonder did he get scammed and is not approved .
Now that would be a shame if Marcel was conned by some one . http://www.nca-anc.com/ does not list him
Home
Industry
Version
Français
Contact Us
Links
Announcement
Inspector Standards
Home
Industry
Version
Français
[/size][/size][/FONT][/FONT][/FONT][/size]
