not too sure, but i would think that if it is asbestos that it would be fine as long as you leave it alone. like asbestos siding. i’d note it and voice the concerns, and move on. it doesn’t look too fiberouse as to become airborn so should be o.k.
Originally Posted By: whandley This post was automatically imported from our archived forum.
Hi Brian; Any chance code check is referring to modern day installations of metal single wall exhaust vent systems? I do a lot of inspections on homes built in the 20’s, 30’s and 40’s and there’s a lot transit tile exhaust vent material running through sub and attic areas.
Originally Posted By: bkelly2 This post was automatically imported from our archived forum.
Will, you are correct. Code check is referring to the current code. I have wondered about single wall transite vent pipes myself. I do not know how hot the exterior gets. Either way single wall pipe clearance is 6".
– “I used to be disgusted, Now I try to Be amused”-Elvis Costello
