Hey everyone! Just wanted your thoughts on this. The seller’s inspector stated that this wasn’t an issue and it’s been that way since the home was built. I wrote it up as a structural defect and to have a structural engineer further evaluate. The other inspector stated it’s not load bearing because it’s not an exterior wall and that it just holds the floor lol. The plumber notched the pier and the footing is showing signs of deterioration.
Please post additional pictures of the footing deterioration and different post angles and what is being held up by the post. You know, details of what you are concerned about.
Jeez that was a hell of a chunk of that pier that has been removed! The other Inspector is an idiot! That sure as hell looks like it is supporting a load bearing beam!!! You are right on track that it is a problem. Even though it has been there a long time you do not know the following.
- How long ago was it butchered? It could have been much more recent than the build of the home. That cast iron appears really pristine and could have been replaced from original.
- When will the conditions be present that makes it obvious that was a totally idiotic thing to cut that support that way? Soils shift, high winds can occur causing movements, etc. Just because there has been no problems does not mean there won’t be any problems later.
Where about are you located?
The inspection was in Salinas, a coastal community in Central California. The column supports the floor and is right near the bathroom in the center of the home. The girder that runs to the left from the column goes to an exterior wall (that also has problems that stemmed from a plumbing issue). I’ll attach that photo as well. I wrote it up as a structural issue and to have an engineer assess.
This is to the left of the previous picture I posted.
They also stated that it was original to the home, which there is no way based on the rest of the plumbing that wasn’t replaced.
The chunk of missing pier appears to be on the ground in the photo, along with what looks like recent sawdust.
Wow, is that footing undermined as much as it looks to me?
If so, that’s is enough to get the SE in there.
Salinas is also prone to earthquakes from what I can find. Therein is one of the conditions that can make that a major issue if a quake occurred of significant magnitude.
Being in Quake Country any type of structural anomaly such as this is in my opinion best called out and when significant enough called out for evaluation by an Engineer. Not being in your neck of the woods I do not know if engineering level evaluations such as this would be common activity for less than a licensed Engineer?
Yes the footing is deteriorating. And to answer the other question, yes that saw dust looks more recent than what the other inspector claimed to be original from the build.
I’m my opinion with this issue, get a SE out there to assess because of the moisture in that area and because of quakes. If he says that it just needs a carpenter then so be it.
I have absolutely never had a problem with an Engineer call out that resulted in the Engineer suggesting they were not needed. I would certainly much rather in these type cases to err on the side of caution than wind up hearing about it later when it required such strong suggestions for the client to get it checked out and they did not.
As Larry pointed out there are other issues for the Engineer to look at. Given those issues we see here there may be even more that you might not have seen or correlated with these that an Engineer may well do.
In my opinion, it is not a huge concern. I would have mentioned it in the body of the report (not the summary) in one sentence , telling them the pier should be repaired or replaced.
It comes across as “hiding it,” not wanting to cause a big deal for the agents, but having my butt covered if something goes bad down the road for the client. Any defect worth a sentence is worth including in the summary, in my opinion.
Totally agree. The way the agent attacked me for pointing it out was something else. Their inspector didn’t mention anything about it as if they missed it.
How did they attack you? They questioned you? Disagreed with you?
She called demanding for my certification information and stated I don’t know what I’m talking about in a very unprofessional way. Yelled and claimed that this isn’t an issue.
I very professionally and politely told her that she was being unprofessional demanding that information and that if she has questions that I would be more than happy to answer them.
She hung up on me as well when it was all said and done.
To summarize I told her that my job is to follow the standards and write defects and assign the appropriate person to look at defects if warranted. In this case with everything I saw, I felt a structural engineer was the right person to be able to determine how much that column lost in strength (along with the footing and foundation wall deteriorating due to the plumbing leak).
Sounds like the Agent is a a real Dink (and a Liar)… Is she saying that the “Seller’s Inspector” said it was no problem? Or just nothing Reported?..Was there actually a previous inspection??? Is this the Seller’s Agent or The Buyer’s Agent? Looks like you are getting in the way of "someone’s 3-6% Commission…Sham on you for being the Only legitimate Person Representing Your Client…
They didn’t put it on the report, didn’t mention it until I wrote it up. Then the inspection company replied that this was original to the build and wasn’t a problem. Yeah it was definitely a commission/lack of finding this defect issue.
From what I understand no allowances.
