Is there a required distance between the plumbing vent and the chimney. I inspected a home and they were only inches away.
What type of flue is being combusted?
The 10-2-3 rule not only applies to the roof surface, but to any object.
Lead flashed vent has probably been there forever unharmed. If the flue was 6 inches from the asphalt shingles, that will be a different matter.
The flue is for the furnace and water heater.
Natural gas, LP or, heating oil.
Thanks.
pictures of that orientation are hard to determine height differernces, which are quite important I think,
Here is what I get from Plumbing Vent Distances & Routing Codes
Table of Plumbing Vent Clearance Distances to Building Features
Nearest vertical surface, distance to plumbing vent - 12 inches from nearest vertical surface.
Nearest window, door, opening, air intake, or ventilation shaft: distance to plumbing vent. - 10 ft (120 inches) from nearest window, measured horizontally - OR 2 ft. (24 inches) above nearest window [or other opening listed at left], measured vertically.
Sorry for the edit, Brandon. Never ran into a situation like this so I added the link.
This post was flagged by the community and is temporarily hidden.
To my knowledge there is nothing in the plumbing, mechanical or F/G code that addresses this installation. Save all the comments here in case you have to defend not mentioning this in your report. No proof that that is prohibit or unsafe.
