Is anyone else having a problem with Fetch…for the past hour I have not been able to get the website up…need to upload a report.
Thanks,
Mike
Thanks,
Mike
It seems like one of the nachi servers must be down because moveincertified.com is also down.
Same here, this is getting to be routine for Fetch! ![]()
Not good.
I am having a problem. Every time I try to install FetchReport I get a pop up which says “printer not installed”. When I click install it, another window says “install failed”. The problem started because the print options for Homegauge does not have fetchreport pdf creator as an option. I must have done something wrong here…
