My wife and I are thinking of buying an 1880 sq ft. home in Regina, Saskatchewan, Canada, originally built and owned by a professional engineer… it has a 9’ height in the basement that’s a PWF with a concrete floor that likely floats on the gravel base.
My parents owned a house in Maple Creek that had a PWF foundation, built around the same time… it had a wood floor. It was holding up well when they sold it a few years ago. To be fair, their soil there in sandier than in Regina.
Unusually, the concrete floor in this Regina house is in remarkably good shape for the clay soil here in Regina, and the walls are plumb. The walls are 2" X 8" PWF studs on 12" centres with blocking on each stud between the floor joists and the parallel exterior walls joists every 12". Seems to be well built. As I mentioned, they are 9" high interior basement walls!
Heating bills, (natural gas) for all of 2015 added to under $800.00, nearly half of what I pay in my current similarly sized home.
I did notice some inward deflection, (maybe 1/2") in the drywall over the studs under each of the 2 small basement windows. There’s only 2 in the entire basement. There’s likely not a strong enough plate on the bottom of the window framing on these 2 windows or enough nails to keep the pressure from pushing the studs in a bit. Or maybe they didn’t use stainless nails and they have failed. Or now that I think about it, I wonder if they used the required joist hangers on the studs under the windows. The house was built in 1983.
There is a small square pit in one corner of the basement with what looks like 2 weeping tiles coming into it from opposite directions. A small sort of large ping pong ball valve resides in the bottom of this pit. Perhaps a backwater valve of some sort? There was a bit of dampness in the bottom of this pit, but nothing significant.
What should I look for, and what should the local home inspector concentrate on? The exterior has positive slope away from the house, nice long extensions on the down spouts, the protection board at/above/below grade to protect the plastic wall membrane is there… all appears to be in good shape.
Thoughts on this major life investment would be really appreciated!
