Originally Posted By: escanlan This post was automatically imported from our archived forum.
It appears to be a second story attempted balcony as you can see windows below, left, with foliage grown under them. Would estimate this is definitely more than 30" to grade.
Correct answer? 8' directly in front of the door to block exit from the
door    . Was that an intentional bow of the floor for drainage, is the floor sagging badly or is it an illusion with my monitor?
That floor appears to be very thin in construction.
Originally Posted By: jquinn This post was automatically imported from our archived forum.
gbeaumont wrote:
Hi to all,
Distance to ground about 9 feet, residential construction.
Regards
Gerry
Alright Gerry, you need to add 1070mm (3'6") to your options, 'cause that's what would be required in Ontario for anything higher than 5' 11"off the ground.
...keeps us from falling into snowbanks
we need the taller railings. When you drink beer that actually has some kick to it (not intneded as a plug for Molsons new beer), you need taller railings to keep you from falling down.
Hi James,
I hear you, I cant get Molson XXXX down here in FL, I may just have to move back to NH for a drinkable beer
gbeaumont wrote:
Hi James,
Regards
Gerry
Sorry Gerry,
Since Coors and Molsons teamed up, I suspect the water taps are going all out trying to get the beer to conform to American specifications.
But that's okay....next were sending you Quebec !!
Originally Posted By: sbyrnes This post was automatically imported from our archived forum.
Gerry,
If you head back up north, pick me up a case too. Do they still make Brador?? It's been a while!
-- All Corners Home Inspections, Inc
Serving Pasco, Hernando, N. Pinellas & N. Hillsborough counties
