Question Of The Week November 18, 2024
Welcome To Questions of the Week!
A member of the Awards Committee will post questions at random.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@internachi.org and submitting your Mailing address for shipping.
Choose your prize from the following list:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
GOOD LUCK!
1) Gas-fired furnace heat exchanges most often fail from
a) Low temperature
b) Lack of use
c) Improper gas pressure
d) Rust and metal fatigue
2) If a system designed for use with natural gas is supplied with propane gas
a) No changes are needed for the equipment to function properly
b) The flame will be too high unless a smaller orifice is installed
c) The flame will be too low unless a larger orifice is installed
d) The gas regulator and valve must be replaced
3) Medium efficiency furnaces have a draft inducer fan and are connected directly to the vent system instead of having a draft hood. There are white and yellowish deposits below the draft inducer fan. A possible explanation for these deposits is that
a) The seal between the draft inducer fan and the furnace is failing.
b) Moisture is condensing in the vent and running back into the draft inducer fan.
c) The draft inducer fan is not operating properly
d) The furnace has failed and is unsafe to operate
4) The service panel enclosure door is required to open at least
a) 45 degrees
b) 90 degrees
c) 135 degrees
d) 180 degrees
5) What is the most common contributing factor to masonry retaining wall movement?
a) Corbelled construction
b) Hydrostatic pressure
c) Poorly mortared joists
d) Too many tiebacks
Great Questions Peter!! :+1: :flying_saucer:
Great QOTW, Peter. :wink:
I’ll give it a shot.
  1. D
  2. B
  3. B
  4. B
  5. B
Thanks for doing the QOTW, Peter! :boom: :heavy_dollar_sign: :boom: :partying_face: :boom:
Great questions, Peter, :thinking:
Good questions Peter THANKS!
  1. D
  2. B
  3. B
  4. B (NEC 110.26 )
  5. B
Music question: Listing to the Sounds of Silence
For #1, insufficient airflow can result in high temperatures, leading to premature failure due to rust.
Thanks Peter
Good ones again, Pete!
Hi there, here just in time to give it a go!
  1. D
  2. D
  3. .B
  4. B
  5. B
Good questions, thanks for taking your time for QOTW Peter!
I say “B” is the answer for all
It is nice to have you all participating. :partying_face:
What Larry said.
Let it be, let it be…
:wink: :smile:
from house I inspected:
b) 90 degrees
great questiobns…
Great questions!
1: D
2: B
3: C
4: B
5: B
I believe the answer are as follows
D
B
B
B
B
