HOWDY & Welcome to another round of Questions of The Week!
A member of the Awards Committee will post questions, at a random day/time.
Eligible members may make one post per question thread to answer the questions.
Correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping
Choose your prize from the following list!:
>$50.00 gift certificate from Inspector Outlet >Case of books “Now That You’ve had A Home Inspection” >Weekly delivery for 2 months of the fabulous new treat Pickles & Rice
Bare electrical wires inside an electrical service panel may safely lay across the grounding bus bars
True or False
2) An electrical charge is
a) Unipolar
b) Bipolar
c) Tripolar
d) Non – Polar in nature
3) An object will NOT have any inertia if it is ___
4) Inspect this please
5) Are there major differences between sewer and septic systems in your home?
a) They are very similar
b) One uses pressure and the other uses gravity
c) The only difference is in the type of pipes used
d) Depends on your diet
Extra Credit!
WHO sang this on WHAT song? hitch up the wagons
1.False
2. a - unipolar
3. not moving (resting)
4. Polybutylene pipes being used, can deteriorate and lead to leaks. TPR tube appears to be reduced at the copper elbows. Hot (outlet) side is only 1/2"… Depending on size of home, this can lead to reduced hot water pressure.
5.(a)
#1 - False #2 - Non Polar in nature #3 - Has resistance #4 - Water heater was observed having its TRP valve terminate into an indiscriminate place. The visible portions of the homes plumbing appeared to be polybutylene. Polybutylene pipes can become brittle over time, especially when exposed to chlorine in water. This can lead to cracks and leaks. Polybutylene pipes may impact your ability to obtain homeowners insurance. We recommend a licensed plumbing professional further review the plumbing of the home before the close of your inspection contingency period. #5 - a) they are very similar
Extra Credit - Ian Munsick & Cody Johnson - Long Live Cowgirls
Polybutylene (PB) piping and improper installation observed. This type of piping is known to degrade when exposed to chemicals commonly found in the water supply (such as chlorine) eventually leading to micro-fractures, leaks and potential water damage to the property.
a) Unipolar
b) Bipolar
c) Tripolar
d) Non – Polar in nature b) Bipolar Charge is bipolar since it can be expressed in terms of positive and negative
3) An object will NOT have any inertia if it is ___ at rest
all objects will have inertia unless it’s a gravity free environment Inertia is the resistance to changing velocity
4) Inspect this please water heater with polybutylene pipes
d) Depends on your diet a) They are very similar
Extra Credit!
WHO sang this on WHAT song? hitch up the wagons Brad Paisley - Celebrity
