Welcome To Questions of The Week!
A member of the Awards Committee will post questions at random.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submitting your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books “Now That You’ve Had A Home Inspection”
GOOD LUCK!
The function of a footing is to
a) Provide lateral support for foundation walls
b) Transmit the weight of the house to the soil
c) Provide support for the basement floor slab
d) Prevent leakage into the basement
e) Resist hydrostatic pressure
Where you have found evidence of footing settlement, how can you predict whether there will be further settlement?
a) Count the number of planes of movement
b) Determine the type of foundation material
c) Determine when cracks were repaired last
d) You cannot predict settlement from a single inspection
e) Determine the depth of the footing
Footings that are continuous around the perimeter of the house are called
a) Pilasters
b) Pad footings
c) Grade beams
d) Spread footings
e) Piers
A buttress
a) Resists vertical forces primarily
b) Resists lateral thrust
c) Is used with step footings
d) Is a type of footings
e) Is not effective in freezing climates
Which of the following is a truss style?
a) Lambert
b) Panel scissor
c) Briggs & Stratten
d) Modified Delta
e) Inverted Belgian
Bonus Question – Write a sentence that ends with the word the.
When talking about a question it would be this and not the.
You want me to write a sentence that ends in the word the?
as Yoda would say: Force be with, may the
