nkienitz
(Nolan Kienitz)
June 5, 2015, 6:42pm
TREC has finally got around to posting the new REI 7-5 template.
I’ve posted links below. One goes to the page where the inspection forms are located and the other is for the REI 7-5 directly.
Texas TREC Inspection Forms:
http://www.trec.texas.gov/formslawscontracts/forms/forms-propertyInspection.asp
Direct URL for PDF of REI 7-5:
http://www.trec.texas.gov/pdf/forms/insp/REI-7-5-PropertyInspectionReport.pdf
Remember that the form can be used “voluntarily” right now, but is MANDATORY as of 09/01/2015.
cevans
(Chuck Evans, CMI)
June 6, 2015, 1:24am
2
Thanks Nolan. That’s funny, I went looking for it last night an it wasn’t there then. I did come across a redlined version on the TREC site, which makes it easier to id the specific changes, but I don’t know if it reflects the final promulgated version.
crodgers1
(Chris Rodgers)
June 6, 2015, 2:37am
3
If you will pardon my laziness, are the changes from 7-4 to 7-5 all in the first section of the report? The format looks the same at a glance.
Thanks
dmaricic
(Dominic Maricic)
June 6, 2015, 7:13am
4
I think they added ONE line!
nkienitz
(Nolan Kienitz)
June 7, 2015, 3:06pm
6
Changes are not ‘extensive’, but you had best be using the 7-5 template as of 09/01/2015. If not you will be subject to fines from TREC.
Note the recent list of fines at the TREC website … many to inspectors not using the current template.
They (TREC) are serious and will fine inspectors for not using the current template.
The new 7-5 is currently “voluntary”, but becomes “mandatory” on 09/01/2015.
Verbiage changes in the template pre-amble, but you also have to make sure your footers are reflecting the changes as it relates to dates and names.
I have another thread regarding this 7-5 changes and a template with the changed verbiage highlighted.
Look for that thread if you don’t want to take the time to review the posted REI 7-5.
cevans
(Chuck Evans, CMI)
June 7, 2015, 10:03pm
7
I ran a difference check between the versions.
Apart from the form numbers and dates, heres what I got:
On Page 2 of 7-4
“· improperly installed or defective safety devices; and
· lack of electrical bonding and grounding.”
now reads
· lack of electrical bonding and grounding; and
· lack of bonding on gas piping, including corrugated stainless steel tubing (CSST).”
On Page 4 of 7-4
“IV. PLUMBING SYSTEMS”
now reads
“IV. PLUMBING SYSTEM”
The above post is for entertainment purposes only. You should not rely on my research for your report form compliance requirements.:mrgreen:
nkienitz
(Nolan Kienitz)
June 9, 2015, 6:37pm
8
… and don’t forget the footers that reflect the new template name and ‘date’ of the template’s adoption.
Tnx, Chuck, I didn’t see the “Plumbing System” change … nor did TREC “highlight” that one in the ‘early’ release they sent to me.
escanlan
(Emmanuel Scanlan, TREC# 7593)
June 10, 2015, 2:56am
9
nkienitz:
It’s an ace in the hole for a $500 fine! :twisted:
nkienitz
(Nolan Kienitz)
June 10, 2015, 12:05pm
10
TREC is serious about the fines. I’ve attached a PDF with a screen clip from the penalties I found for April-2015.
