Replace flex gas line connectors?
I am looking for a source that requires replacing a gas line connector when an appliance is replaced (for example a water heater). Some manufacturers state “do not reuse” on the tag. Does anyone have a reference to a standard or code that says gas line connectors must be replaced when the appliance is replaced?
Thanks
Here it is on page 2
http://www.dormont.com/dmc/uploadedFiles/res/ResourceCenter/RES_instructions.pdf
Hot dang your good. Thanks.
2006 IRC says:
Thanks Bruce, I didn’t know that was required.
Nor have I ever seen it replaced that I can remember.
On another note, I write this condition up on gas connectors about 1/2 the time.
http://www.applianceaid.com/gasconnector.html
We also recommend replacement of any Brass Flex lines as they have been recalled.
