I was cleaning my gutters and noticed when my roof was installed a few years ago they did a poor job of cutting a shingle. The exposed fascia is rotted as it is not sealed.
I was wondering the best way to repair this?
Should I replace the entire shingle?
Cut a small section and use nails and roofing tar to repair.
If that is the case and there is shingle overhang of the drip edge the balance of the rake You could work a flashing between the starter row and first row…using plastic roof cement to seal between flashing and both layers…covering the exposed area…i would use no nails here…I would not be at all surprised to find the only rot in that fascia is at the exposed spot and if sealed and flashed would be of no future consequence…jmo…jim
Exactly…using metal (shingle color match if possible) you could hem the edges and extend it to the eave of the first shingle covering the exposed wood and angle it back to the bottom edge of the second course and tuck it under that.
If the fascia is not badly damaged, then simply slide another shingle under the existing shingle and fasten it. You do this by getting a pry bar and prying up the roofing nails from the underside of the existing shingle. Then get a new shingle and match it up to the existing shingle and cut it to fit/match the existing area. Then slide it under the existing shingle and re-fasten it.
I certainly agree with David. No need to go through any extensive repair untill the next time the shingles need to be replaced. Then I would install metal drip edge around entire house.
Did you NOT read the first thread post. He states “Rotted”. That being said, its an infection and will continue to grow, damage and or deteriorate the surrounding sound material. Masking the effected area with edge metal, shingles or mastic will not ensure structural integrity of the member.
I’ll answer my own question… If infection is present, it should be removed as part of any subsequent repair…
Posts #10 & #11 appear to address why I’m debating the issue. As inspectors and contractors we find improperly repaired issues on a daily basis which lead to more extensive damage and increased repair costs. This small area of damage in the fascia can extend to adjacent sheathing and or rafter framing if left untreated and or in place.
BTW, here in California the Structural Pest Control Board refers to items of issue as being “Infestation” and “Infection”…
I used an exterior wood filler/hardener. Then covered with a like colored flashing. Used roofing adhesive to adhere. I then cut a section of 3d shingle off the shingle pictured at the roof edge. I placed a small section of shingle under the original shingle along the rake and between the added flashing.
It came out really well and I thank all of you for your suggestions.
Thanks
I will take a picture and post as soon as I get back on the roof.
