Roofing Co & Structural Engineer
I recently conducted an inspection in Dunedin, FL. My client wants to make a roof change from asphalt to tile. Can anyone recommend a roofing group that has both the ability to quote a job in concert with a structural engineer to approve changes from concrete to tile in the Dunedin, Tampa, St. Pete area? Just looking to see if anyone has a roofing contractor recommendation. Thanks
I’m not sure if they go to Tampa, the only roofing company I’ve heard good things from clients and have personally inspected their roofs was Kelly Roofing.
Was the roof sheathing plywood or OSB?
Dave thanks for the tip on Kelly Roofing but too far north for them. Sheathing is plywood, but not a factor either way. Client will change out roof deck entirely if necessary to achieve their desired look.
