A recent post mentioned unsheilded rubber gaskets on drain pipes which was something I had never considered in the past. Now I’m second guessing every coupler I see. Today’s inspection on a 52 yr old (1974), 2,892 sq ft, 3/3 on a crawlspace had several of these connectors. Some I can tell won’t last due to the offset between the pipes. Other’s I’m not sure about. My understanding is the flex pipes are a temporary fix and the couplings should be addressed by a qualified plumber. The couplings aren’t designed to handle the weight of the pipe and should be properly supported, and, they are susceptible to rodent/vermin/pest damage. Is it correct to call this our for review and possible repair by a qualified plumber? Any advice would be appreciated.
Damn, they must have been on sale
Looks like lots of generally old plumbing to call out there so you could throw in the rubber connectors as something else to have looked at. If I run across one or two and they are well installed and functioning I don’t call it out.
With things like this I always have in the back of my mind, what’s the downside of not calling it. Or, more to the point, if some plumber throws me under the bus how much could it cost to remedy? It’s not like I’m going to get sued for six-figures. I’m far harder on other aspects of a house that could burn me (water intrusion/concealed damage, foundations, etc.). I just don’t see the point of dying on a hill screaming about a rubber fitting that is working perfectly fine.
You will probably get a variety of opinions ranging from “no big deal” to “imminent failure”.
In my state I am required to describe DWV piping materials. I identify above ground un-sheilded rubber couplers as a non-standard repair and at a minimum, recommend that the client monitors for the defects that you mentioned. InterNACHI SOP does not require describing piping materials.
You do realize most of these repairs are done by plumbers, there is no good way to attach PVC to galvanized pipe. The PVC to PVC repair could have been done differently with a slip coupling. But it’s still an acceptable repair.
You can report it if you like, but as soon as a plumber looks at the photo you are reporting on when the fitting is not damaged or leaking he is going to talk shit about you to his agents he works with. The word will get around.
You should only report on defects and improper things. Rubber fittings are not one of these. They are UPC listed as an proper repair fitting for drain pipes.
only if the pipe is the same size. In most applications this does not work.
Not many at this property but the drain line ran past the crawl space access so they made a way to get through. Pretty thoughtful.
Thanks for the insight everyone. I always look at it from the “what can they sue me for” perspective, which, while a reality, is a sorry way to do business. I try to look out for my clients best welfare and make them fully aware of the property without being an alarmist.
I’ve seen the rubber couplings around and never wrote them up unless there was a defect or improper installation. However, a thread a few weeks ago was talking about them and then I run into a murder of them in the crawlspace. Again, thanks for the insight.
