Self-closing device on garage-house doors
Originally Posted By: jgallant
I’ve heard from 2 different sources recently that codes have changed in the last year so a self closing device isn’t required on doors that separate attached garages and living spaces. I’ve always checked for and reported on the lack of a self-closing device on such doors, along with lack of weatherstripping, and/or lack of a fireproof door.
Is anyone else aware of this change in code(s)? Anyone stopped reporting on self closing devices who previously had been?
-Jim Gallant
Owner, All Point Home Inspections - Poulsbo, WA www.allpointinspections.com
Co-founder, ReportHost (Web-based report writing service) www.reporthost.com
Originally Posted By: jpope
It appears that this is a UBC requirement only. R309 of the IRC does not mention self-closing devices.
Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
Originally Posted By: phinsperger
I believe they are still a requirement up here.
Paul Hinsperger
Hinsperger Inspection Services
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
Originally Posted By: mcyr
Hi. Jim;
I agree with Jeff, the 2003 IRC 309 does not mention the fact of self closing doors. I would personally check with the local code inforcement for your area, because most ussually, local codes are the last say to what ever code has been adopted.
Take care
Marcel
Originally Posted By: dvalley
" on the GARAGE-Entry door portion of my report.
Code or not, all my clients are aware of this issue.
David Valley
MAB Member
http://www.masscertified.com
Originally Posted By: rcooke
Garage doors.
If I find they do not close . I call it for safety reasons I also make sure they have a good gasket to the home also to keep out fumes and check the auto reverse and eye if the big door has it . I make sure I have written it up if they do not fix it NO MY FAULT.
Roy Cooke sr … Royshomeinspection.com
They do not require self-closers in my state either.
We had a family where the dad came home to get his kid to take to day care . He stopped in the garage and decided to have a coffee with his wife . TWO adults and kid over come by fumes .neighbour saved the family . How can I get in trouble for a safety recommendation .
I would still write it up as safety . Roy Cooke CRA!!! Cover Roy's a$%
