Is there a required shower door size, i.e., minimum 24 inches wide?
No there isn’t Peter, that I know of, or read in any code book…“nada”.
Depends on the “width” of the client. ![]()
True…I do know some folks who would not fit through there even greased—![]()
I thought I heard a greased pig could slip in any opening. :mrgreen:;):)![]()
Thanks for the visual Dale! ![]()
helps if they open outward, too
less than 20" on this one :shock:
Like a sauna, a shower door should open outward for safety reasons.
I guess you got in the shower to test this one…
I am a bean pole, so entry/exit was not a problem. Opens outward.
It’s new construction, so I was concerned, and recommended review of the plans, etc, etc, etc.
Richard M was close–there is no door minimum, but the maximum user size is directly proportional to the entry opening.
Well, 14 years later, I found a small shower door opening of 18 inches, and, yes there is a minimum size of 22 inches.
Bet that kept you awake at night! ![]()
You would think, but nope, not at all.
Philippians 4:6
I concur, Peter. 22" inch wide for a shower stall.
