The drain fittings do not appear to fit properly. I was told the builders plumber installed the drain. Any ideas. I wrote it for a licensed plumber to evaluate and repair
It appears that the builder’s “plumber” was ill equipped on the fittings that day and improvised with what he had.
“But it doesn’t leak!!!”
That would be my advice too.
A properly sized, in length, tailpiece and 90 would eliminate the visual confusion, although I can not see how the present 2 waste arm arrangements will affect the drainage flow.
Could you provide an image of the trap weir and vent arrangement please?
You got that right!
Poor guy…plumber, eh?
Yes…
That…^^^^^^^^^^^^^^^^^ …and next time you can skip “evaluate” and just jump to repair…IMHO.
Good job, David!
