sheesh lolollll unreal what some do n claim, sorry i wish i could state diferently but the truth is the truth n this guy does NOT know how to correctly determine why basements leak… and by the way, does he give homeowners a 10, 20 year guarantee that their basement will not leak after he screws around with the grade?
fast forward if you rather to 5:35, 5:50 6:15 mark in video, what do you see lol
Drainage Assessment - Finding source of basement flooding - YouTube
That’s a pretty lil blue You tube shirt ya got on Mr water diverter guy
this basement needs some exterior waterproofing done correctly and may also needs some tuckpointing etc above grade
pouring more concrete, new concrete is not going to keep the basement dry, neither will installing a french drain but go ahead n keep doing the weak stupid shtt and see where it gets ya
if you run water, a hose test, and ya get water in then there IS, ARE lol, exterior openings in the basement wall such as ext crack (s) cracked parging etc and fairly often when morons RAISE the grade with soil or concrete, they don’t seal the bricks and mortar joints where they are raising the grade and so then some of the bricks or mortar joints crack, deteriorate and here comes the water in basement, effllorescence etc.
so you think you can divert all water away from the full depth of a basemet wall huh, keep it from hitting the basement wall at 2’, 4’ 6’ deep, well lots of stOOPid luck with that, you’d better hope n pray there is all SAND down there
this video, guy just bought the house, sellers installed an interior basement drainage system and sump pump $$$. He moves in and basement leaks and he sees more mold, efflorescence on wall, finds my dumb azz n calls. I go over there n run a water test with a hose, just to show/prove to him where the problems are, have always been before the INT system was installed which were, exterior cracks in block wall… yeah water began entering onto his B floor within 2 minutes
there was a driveway up against the house/wall, i could have saw cut it and saved him $$$ but he wanted new driveway anyways. Wa done about 5 years ago for lil less than $3,000, NOT anymore costs have gone UP quite a bit and shtt, ya’s got $15,000-30,000 for these INT system companies so you are gonna start paying us a bit more if you want your shtt done right, yep.
to all these contractors who install french fry drains n add 100’ downspout ext’s etc, let me see that guarantee from YOU that the basement will be dry for at least 10 years after you install the surface water diverting bs
