Solar panel inspections training
I have a question I would love any helpful feedback. I am newer to the home inspection industry in Florida. From searching the forum, I see a lot of inspectors will “inspect solar panels” when doing home inspections for “damage” on panels and damage on roof” from panels but clearly notates recommended further evaluation from a solar professional for a system check.
My question is this… I notice ton of communities that are being built near me in Florida that majority of homes all have solar panels installed. I am thinking having an ancillary service doing a full solar system panel inspection. Then is my question is there any recommendation for full solar training and Certification as a solar system inspector y’all have experience with? I would want focused training and the certification would bode well as a selling point to clients as well has increase my expertise.
Sprk, you should be able to Google it, I am just starting with them now for solar
Thank you. I am looking them up now
Reference the manufacturer’s installation instructions for the system(s) installed. The most common defects I see in my area are typically the structural attachment of the panels.
I looked into the topic of solar system inspection as an auxiliary service before. I came to the conclusion that it was simply not a thing in the industry. The only courses I could find were how to become a system installer, which I presume would do very little to help you evaluate whether an existing system in good condition or faulty. If you find a course on how to inspect an existing system, preferably with some type of training certificate, please let me know. It would be great if InterNACHI was able to add a certified auxiliary course.
At present, I disclaim any solar system expertise, but as a courtesy, I attempt to figure out the nominal wattage and age of the system, plus report any obvious problems such as blinking red lights; broken, dirty, loose or shaded panels.
Get about $6k out of your piggy bank and go get certified as a Lvl II Thermographer, and a camera.
Add a Thermal Drone and you can inspect those giant solar fields all over Fla.
Before you do, determine who your market is.
Residential inspections seldom pay out for the cost of investment. Like about everything else ancillary, who would look for a Home Inspector to fix solar panels at the cost you need to charge?
Agree, there does seem to be a small market in the commercial inspection arena for that… However, I do not think that detecting panels with issues using a thermal camera drone is the only service that is desired. Perhaps I am wrong, but I would expect that the client would want to know what is the actual specific problem with the panel (it could simply be a loose wire, for instance) and, perhaps, how much will it cost to fix? As such, I was thinking you would need to be a licensed solar installer with said drone and have “Solar” in your company name to be truly marketable and credible.
When I was in Maui I saw a lot of panels and people really wanted at least some information so I came up with this:
A basic check of the solar system was performed, and it was found that some power from the panels is being fed into the house’s system. The panels on the roof were also viewed and found to have no obvious physical damage. A more specialized inspection from an installer or service person is recommended if more information about the system is desired.
I’d include a picture in the report of my voltage sniffer on the wires coming from the panels being live.
Yes, that is an unknown however.
I live in a county with a massive industrial complex growth that can’t afford Nashville, Tn. I worked on many of them that have been around a while (HVAC). I could not get anyone that did not subscribe to the "Run it till it breaks. Even though the shutdown costs hundreds of thousands for everyone to just hang out till the problem got fixed. That market needs to be found.
No, it is not. You’re correct. You must be a full service contractor. I have a group of support contractors to work all the way up to nuclear.
That is what IR does. You can direct every cell in the panel that is or has gone bad. It may still work, but the increased load on the panel will make it fail. You can also see every connection that is failing at a very short time, lower cost inspection that they can afford. That’s if they are proactive on maintenance.
Cost to fix is not my job, and should never be for any inspector.
Not true. I work for drone pilots. I’m not installing anything, and neither are they. Installers work for pennies, They install.
How much is that worth to the client? What will they say when the bad cells cause failure under higher load than at the time of inspection? :thinking:
People get killed from electricity. What does your Insurance Provider think about you claiming proficiency in the solar field of inspection?
I disclaim the solar system as fully outside my scope of services and report anything I observe as a simple courtesy to my client. I am not sure what the value is; however, it is often basic information that is typically not provided in the MLS listing. I have a found a couple of broken panels, which was at least appreciated by the buyer. The agents are mostly just interested if the solar system is “owned” or “leased” that can really complicate the transaction.
David - I wish you would share more about your IR camera work detecting problems with panels. I tried that a few times from the ground, but it is rare to have the right camera angle and sunlight. I suspect that you would need a IR drone that flies very precise routes (to get the angles correct) and you inspect at the optimal time of day and need the right weather conditions, correct?
Perhaps you should use the SEARCH feature to look up Charlie Bottger’s old posts regarding aerial IR and his use of helicopters…
Note: Charlie is an old school veteran inspector goin back to 2004-ish, and retired a few years before you joined, so in case you haven’t been exposed to him yet… Profile - cbottger - InterNACHI®️ Forum
Nick and Ben once talked about an upcoming Solar Inspection course.
Then one day, all those posts magically disappeared, and the class never happened.
But there are 4 NACHI videos on YouTube that I presume were going to be part of the course that you can easily find by searching on YT.
I checked all those out today Ian. Thanks. Good coverage of the absolute basics, I would say. However, my insurance company would want to see that I have taken a certified training course, preferably from InterNACHI. Also, I think that any homeowner would want to get some level of comfort that the system is working properly (efficiently) for its age. Nothing from InterNACHI has touched that.
The only training and certification I have found so far is: NABCEP PV System Inspector (PVSI) training and board certification. The exam is $150 with no prep or prequalification necessary. However, there are prep courses and practice exams provided by third parties(e.g. HeatSpring) that start at $895 for a two online courses which includes a practice test. The video at this link is a pretty good overview:
My overall impression is that the course (test/certification) is geared towards building and code inspectors inspecting new system installs, and therefore, goes way too deep into the NEC for an auxiliary service with a home inspection.
