Sometimes I just don't understand things...
The line out of the wall (I think) comes from the laundry discharge from the floor above. Then it goes up icon_question.gif and then down to the sump pit below (not shown), however the longer line goes (towards the camera)to the other sump pit. Can anyone explain this? is this an overflow line?
Originally Posted By: tallen
Huh?
Originally Posted By: jbehling
tallen wrote:
Huh?
Sorry Kevin, I tried to follow all that too. Couldn't make heads or tails of what you are asking ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
sorry, but the picture pretty much explains it.
Originally Posted By: jpeck
IF it comes from the laundry, did water come out there when the clothes washer was operating?
Sounds like they may be draining the clothes washer to the sump pits, then having the sump pumps pump that water out?
Jerry Peck
South Florida
Yes, that’s what’s happening, but I don’t understand why it’s draining to two sump pits, and also why it’s plumbed the way it’s plumbed. It’s just plain goofy…(that’s a technical term)
Because it was too much all at once for one sump pit and pump to handle.
Clothes washers pump out a lot of water all at once.
Maybe someone wanted to slow the flow down by making it 'back up' a little?
Jerry Peck
South Florida
Jerry, that actually makes sense! Thanks.
The sump dumps on the lawn which is illegal according to the DNR (gray water).
Originally Posted By: phinsperger
Kevin,
Did one not too long ago that was plumbed similar to yours. Washer drain went up though a wall and down into a sump (single only) to be pumped outside. Then beside the sump for the washer were two more foundations sumps that were connected to each other. The washer sump was not connected to the other two, thank goodness. All three pits were side by side and all three had pumps in them. I guess the second foundation pump was just a backup.
Paul Hinsperger
Hinsperger Inspection Services
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
Originally Posted By: dvalley
Kevin,
Another uphill plumbing fix!!! It looks to be working as an overflow pipe. You'd think they could have come up with a better piping situation.
I also had a similar piping situation. The washing machine was draining through the pipe entering on the right side of the cabinet. I tried to figure out how the hell the water leaves this piping configuration as it gets pushed up hill.
![](upload://lgyRDhz0WxX7wrkJfg0g6SeENtr.jpeg)
David Valley
MAB Member
http://www.masscertified.com
