Spliced rafters
Originally Posted By: rdawes
Hip Rafter Splice ]
The rafters were spliced with OSB on both sides and seemed to have decent purlin supports.
[ Image: Rafter Splice ]
Are these something you would mention? If so, how would you word it?
Thanks,
Ron
Originally Posted By: Jay Moge
not positive, but i’ve always thought that; rafters can be spliced, but it should be by the following way. the same matterial as the rafter/joist is to be used on both sides of the splice and adaquately fastened lateraly at least 2 1/2 times the highth of the joist/rafter and though bolted atleast every 4-6 inches offset. thats the "rule of thumb’’ we used when i was a roofer. (years ago and not for long.) hope i’m close. we’ll soon see. icon_cool.gif
Originally Posted By: jpope
Looks okay to me. It would be a different story if they were trusses.
Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
Originally Posted By: lkage
I agree it looks adequate in it’s present condition but it sure is another reason to keep the attic dry. OSB and moisture don’t mix well.
“I have never met a man so ignorant that I couldn’t learn something from him.”
Galileo Galilei
Originally Posted By: Monte Lunde
It does not look like a splice to me, blowup the photo and you can not see a joint. If this was a splice the nailing pattern is not correct (2-1-2-1) also no glue squished out on the ends of OSB
I agree with Jeff and Larry
Monte Lunde CCI, CCPM, CRI
Viking Construction Services Inc.
Originally Posted By: mcyr
Ron; The spice would not bother me to much for that part of the Country.
I am assuming that the knee wall struts are bearing down on a bearing wall below?.
Monte; That was a good observation on your part and must admit that was the first thing I notice, very few nails and no evidence of structural adhesive. The other thing I noticed is that a filler was used to maximize the splice width, but now nails are visible in the scabs to it.
Looks strange,? call it as you see it Ron. That way you are covered.
Marcel
Originally Posted By: jonofrey
The hip rafter looks spliced to me but okay. The common rafter probably just has OSB tacked to them because of a crack or something.
I wouldn't even mention it if I saw this on a pre-drywall inspection.
Inspection Nirvana!
We're NACHI. Get over it.
Originally Posted By: ccoombs
They look fine to me…and they look like they were detailed/engineered. Because this is a warranty walk, I would note that repairs were made and suggest they request copies of the engineering for their records. That way when they go to sell and the HI calls them out they don’t have to track down the builder, engineer, framer, etc. with a time limit.
Curtis
Thanks folks for the advice.
Cheers,
Ron
could this be part of the attaching method used to join prefab. units. i.e. an added on inlaw apt. or such? icon_cool.gif
