Originally Posted By: phinman This post was automatically imported from our archived forum.
Interesting!
The picture does not tell the whole story. Since it has been there for 65 years there is some other support somewhere or it configuration would have pulled apart.
The notch at the top along with a notch at the last risers at the floor and some side support may explain why it has not failed, but actually after 65 years it looks to be performing ok with me, an old stairbuilder and broken down carpenter!
Originally Posted By: cbuell This post was automatically imported from our archived forum.
Phillip, I have to agree with you that “there is some other support somewhere or it configuration would have pulled apart”. But, unbelievably, the side stringers are not attached to anything. What you see in the picture is all there is. Looks like some damn sucessful toe nails to me! Also there is no “positive” connection at the floor either.
Joe,
Unfortunately I didn’t photo the rest of the stairs----I wish I did now. There are no midspan supports. There are three stringers with one attached at the bottom to a beam support post. Granted this does give some support but the support at the top would still at best be marginal. It is amazing how when you know something has been functional for 65 years your mind wants to convince you that the way it is is OK!
Originally Posted By: rmoore This post was automatically imported from our archived forum.
I’ve been functional for 55 years, and I know I could use some improvement.
I think Dave Valley had it right. Some metal brackets or strapping would be a cheap, easy fix that could only help and would certainly do no harm. Go with you gut feeling Charlie.
-- Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Originally Posted By: jpeck This post was automatically imported from our archived forum.
Ever lean a length of wood up against the side of a house? Ever lean a ladder against the side of a house? Did you climb the ladder without strapping it to the house?
Of course.
IF, and that is the key and it has apparently been true for 65 years, IF the bottom of the stringers are anchored and held tight against movement, those stringers cannot go anywhere ... unless the double header they are resting against move.
The nails are not providing the most resisting force, the wood leaning against wood is. The nails are 'backup'.
Would I recommend leaving it this way? ARE YOUR CRAZY! No way.
