Found what I think is a steam generator under a bathroom sink. I am not familiar with this. I tried to find information on the company but I think the Co. is out of business. Does someone have info on this? A site that has info or year made? Thanks for any help.
Drain is leaking onto the electrical j-box, yikes. I think I’d call for removal for safety reasons. At least it’s in a pan.
Nope, never seen one of those before.
Looks like an old steam generator for a sauna or steam shower. Even if it operated for me at the time of the inspection I would probably recommend evaluation by a plumber familiar with steam generators.
That unit does not look like it has a drain hooked up, if not these units will get clogged up with calcium, I have worked on a lot of “Amerec” units in the past.
That’s what I think also. I did call for a plumber. That gray box on the right is a transformer for it. Should have an electrician look also. Would be easier just to remove it. Here’s some info on the generator.
