help with weird plumbing fittings
I do not know what this is. It is under a kitchen sink in a 1983 condo. it is downstream of the garbage disposal and is tapped into th cold water supply. Is this for helping to move solids down or what??
RO drain?
Ditto:D Hi Bk
Is that the top of a saddle valve I see?
Any one have thoughts on cross contamination?
yes that is a saddle valve.I dont get the purpose of this connection at all.
I see what you are talking about, maybe a disconnected Ro unit thanks that is a great possibility. thanks brothers
John
Was this the whole ball of wax with no filter.
Straight from the water supply to the drain?
I wonder if at one time there was an RO unit and when they remoced it they just cobbled it back togehter the way you see.
And yes I vote cross connection Bob unless one of those do-dads is some sort of checkvalve.
Remove, or have a plumber evaluate it.
Great ? on the cross contamination. there is a shut off valve that is not visible in the photo also the saddle valve is closed so I dont see how this is an issue but am all ears for input
John
yes Robert
Thats what I was hinting at Brian, just wanted a second opinon.
So there ya go John.
Also I will add saddle valves are not allowed as they leak.
Tell them to include that as a defect.
You were at it while I was typing slow as usual John so let me add that closed or not it has potential.
I could put a conductor on your a-s and tell you its safe since the switch is flipped,\:D/
Can you open the shutoff valve??? :smiley:
Some one could open the saddle valve or it could be partialy open with you not knowing.
Yum doesn’t that year old meat taste good with a glass of water.
thanks Brian and Robert. points well taken and appreciated. thanks for the analogies I think I will use those quotes in the report.he he
John
