This basement on a 1950-1960s house had multiple (8-10) steel support posts. Some were supporting the beam. The one showed here was under a floor joist and it had a 4x4 and a 1x4 in between the top plate and the joist. It was not fastened to the “buffer” boards. Is this a problem if this is not a bearing beam?
Also, the posts that are supporting the beams were attached using nails instead of lag screws. Thanks for the help.
Thanks for the reply Larry. I don’t know if it is or is not carrying a load and don’t want to speculate on that, it just seems to not be carrying a load because it’s not under a beam - just the floor joist. There are 7 or 8 more of these that are all under beams (those are the ones secured with nails only).
