pmagrone
(PAUL MAGRONE, Florida License # HI 30)
I have a friend who had a home built in Windermere, Florida in 2006 by a well known builder. The stucco and paint that was applied over the concrete block structure and wood gables has started to crack excessively, especially at the front gable. The cracking was already sealed but I wanted to post some photos to get other inspectors input. The cracking does not appear to be typical and I noticed that the paint did not appear to be applied evenly. Any thoughts?
One of these years they will start puting moisture barrier over the block parts as well and the lines will go away and the cracking on the mortar joints will also!
And the moisture problems will be reduced! Imo
pmagrone
4
The builder has come out to the home and stated that there is no problem there. I did not do an inspection on the home yet but want to be well prepared in the event that I do. You asked all good questions. I will be sure to look for those things when I get out there. I love this message board because of the many good inspectors that respond to the posts. I want to help this person get some recourse for the job that was done to her home. All input is appreciated.
Stucco regardless of what application is used, if applied/installed correctly there should not be any problems as you well know being a stucco contractor all your life.
For the life of me I cannot figure out what is so hard about simply installing it correctly.
Flashing seems to be some sort of rocket science to most builders, damn if I can figure that out.
It would really help alot if the codes officials and their inspectors would enforce the codes!
Alot of stucco jobs all over the counrty will fail due to what the carpenters have done and gotten away with, before the stucco contractors of today get to the job!
“Flashing seems to be some sort of rocket science to most builders, damn if I can figure that out.”
time and material!
ain’t busting the budget on some stinking metal crap that ain’t on the plans and ain’t spending more time than i’ve had to in the past. them illegal’s wages are skyrocketing to what we paid tradesmen back in '75, '85, '95, '05 and these home inspectors want us to train folks that don’t savey our lingo
i’ll bet the bond is bad look at the moisture retention/efflorescence at the cracks
tap-tap-tap…cruble-crumble-crumble
if the mortar joints in the block telegraph through the base/scratch coat was not applied thick enough, aka construction application defect
