Student Discussion: The 2021 International Residential Code® (IRC®) Exam Study Course
  • What is the minimum required thickness of masonry walls? Parapet walls?
R606.4.4
Unreinforced solid masonry parapet walls shall be not less than 8 inches (203 mm) thick and their height shall not exceed four times their thickness. Unreinforced hollow unit masonry parapet walls shall be not less than 8 inches (203 mm) thick, and their height shall not exceed three times their thickness.
  • How are ducts to be insulated and sealed?
Ducts in unconditioned spaces shall be insulated to a minimum of R6, R8 minimum in certain climate zones. Insulation may be excluded only if ducts are within 15 degree temperature differential. All ductwork seams, connections, and distribution boxes shall be sealed.
  • How must a masonry fireplace be supported and reinforced?
R1003.1 discusses reinforcement for chimneys. The code provides provisions for foundation design requirements, seismic reinforcement, vertical, and horizontal design as well.
  • What types of inspections are specifically required by the code? When are inspections required?
Post Your Answer Here Building codes necessitate specific inspections, such as foundation, framing, electrical, plumbing, and final inspections. These checks occur at critical construction phases to guarantee adherence to safety and regulatory standards.
So far I like the course, but the instructor doesn’t seem to realize he can do more than 1 take.
  • Where must mechanical exhaust air terminate? What locations are strictly prohibited?
Chapter 1501.1 Mechanical
Exhaust duct terminations must exhaust outside the building envelope in a manner where contaminants cannot be reintroduced to the indoor environment. Exhaust ducts may not terminate in crawl spaces or attics, nor exhausting to the point of termination at or around other ventilation systems, such as off ridge vents, gable vents, or soffits.
  • What is a dead load? A live load?
R301.5Live load.
P
The minimum uniformly distributed live load shall be as provided in Table R301.5.
R301.4Dead load.
The actual weights of materials and construction shall be used for determining dead load with consideration for the dead load of fixed service equipment.
My Response. In the IRC (International Residential Code), dead load denotes the unchanging weight of permanent building elements, while live load refers to the variable weight from occupants, furniture, or moving loads.
  • What is the minimum ceiling height permitted for a living room or bedroom? A hallway? Bathroom? Basement? Where can a reduction in such heights be acceptable?
Ceiling height requirements vary by location and building codes. Typically, living rooms and bedrooms require a minimum of 7 feet, hallways and bathrooms 7 feet, while basements and water closet 6,8 and 6.4 where ducts may hang down.
In reference to Writing Assignment #1, 2021 IRC Exam Study Course:
The building permit is required when any owner and or owner’s authorized agent intends to construct, enlarge, alter, repair, move, demolish or change the occupancy of a building or structure.
This work is exempt from permit when such items as storm shelters, retaining walls less than 4ft in height, decks under 200 sq ft ect. are constructed. See R105.2 for full details and exemptions.
In reference to Writing Assignment #2, 2021 IRC Exam Study Course:
Light - Frame construction, Construction whose vertical and horizontal structural elements are primarily formed by a system of repetitive wood or cold formed steel framing members.
In reference to writing assignment #1, 2021 Exam Study Course:
The purpose for the code is to establish minimum requirements to safeguard the public safety, health and general welfare through affordability, structural strength, means of egress, stability , sanitation, light and ventilation, energy conservation and safety to life and property from fire and other hazards attributed to the built environment.
The code shall apply to construction, alteration, movement, enlargement, replacement, repair, equipment, use and occupancy.
  • What is the minimum size required for a landing? Under what conditions is a landing not required on each side of an exterior door?
The minimum size required for a landing is typically 36 inches by 36 inches. A landing is not required on each side of an exterior door when it opens directly to a deck or patio at ground level.
  • Under what conditions is an unvented crawl space permitted?
Unvented crawl spaces are permitted when they are adequately sealed and insulated to control moisture and temperature, maintaining indoor air quality, and complying with local building codes and regulations.
In reference to Writing Assignment #3, 2021 IRC Exam Study Course: The minimum required size of the largest habitable room in a dwelling is 70 square feet of floor area. R304
framing is made from strips of structural quality sheet steel that are fed through roll-forming machines
  • What ledger connection details are required for decks attached to exterior walls?
To ensure the safety and stability of decks attached to exterior walls, essential ledger connection details include accurate positioning of the ledger board, appropriate anchor bolts, secure spacing, and effective flashing to prevent water damage.
All of these essays are great. Good work, everyone. Keep going!
In reference to Writing Assignment #4, 2021 IRC Exam Study Course:
Landings shall have a dimension of not less than 36 inches measured in the direction of travel. The Slope at exterior landings shall not exceed 1/4 unit vertical in 12 units horizontal. R311.3
Landings are not required at the top of an interior flight of stairs, including stairs in an enclosed garage, provided that a door does not swing over the stairs. R311.7.6 Ex
  • What is the criteria for the installation of weep screeds in exterior plaster applications.
The installation of weep screeds in exterior plaster applications follows certain criteria, typically including proper placement at the base of the wall, correct slope, and spacing to allow moisture drainage and prevent water infiltration.
  • What special conditions apply to the installation of a solar energy system?
Chapter 23 of the IRC provides guidelines for installation of solar energy system. Considerations for access to the equipment for maintenance, design and installation, labeling, etc. Special instructions are provided for systems installed for heat transfer gas or liquids and heat exchangers.
In reference to Writing Assignment #5, 2021 IRC Exam Study Course:
Unvented crawlspaces are permitted when a Class I vapor retarder overlapping 6 inches is installed.
A continuously operated mechanical exhaust vent installed, A conditioned air supply sized to deliver at a rate equal to 1 cubic ft per minute for each 50 sq ft of underfloor area. R408.3
