Caption in-part, she writes, “This is a video of a waterproofing job gone terribly wrong. We hired a company to waterproof our leaking basement, they advised us it HAD TO BE done from the INSIDE… We’ve since learned that this should have and can be done from the outside” Got that? Homeowners words not mine https://www.youtube.com/watch?v=(http://abcnews.go.com/WNT/story?id=131638)
“LOCATE and fix leaks immediately. You MUST FIND the water source and ELIMINATE it”
They do NOT say, as the inside system morons do, to don’t bother taking the time to find the water source/problem and it’s fine to allow the water to continue to enter and re-route it along perimeter and into a stupid sump pump.
Interior knotheads don’t know or don’t care about where the water is actually entering, no they don’t! They will come to your house and tell you one or more lies, misrepresentations of what you have and what you supposedly need and it’s always an interior butthead system.
Some homeowners get water in basement ONLY because they have 1+ exterior openings under/around a basement window or door or above grade in their chimney. shttt like that. Well duhhhhhhhhhhhhhh, you MUST take the time to find how/where the water is getting in and NOT just go to people’s home and not bother to locate/find the source/problem and instead tell them all they need is a stupid, piece of crap interior water DIVERTING system and sump pump.
Prime examples of knothead companies who installed an interior system when the homeowners problems are exterior cracks, cracked parging and some openings above grade and so they did not stop the water and did not stop mold https://www.youtube.com/watch?v=3KFycoizC84)
Again, in this video an interior basement drainage system was installed, did it stop the water from entering which would have stopped mold? Noooooooo! https://www.youtube.com/watch?v=i9uobsggb5M)
Ya think there’s a mold, efflorescence problem in this basement? https://www.youtube.com/watch?v=HALcgt9ho2M)
She had multiple exterior cracks, cracked parging on the outside of her foundation walls, as usual!
AND… it COST $10,000 LESS than had she hired an interior system company!
BUYER moves in house where the seller had an interior system installed costing $$$$$$$$$, still leaks, mold, efflorescence etc https://www.youtube.com/watch?v=SuhoPPs3YDI
Buyer hires us to waterproof his ACTUAL, existing problems and to relieve/lessen the weight-pressure against the foundation wall… this is what WAS needed allllllllllllllllllllllllllllllllllllllll-along, it is what should have been done before, it’s what should have been done INTEAD of bs’ing the seller and installing that piece of junk interior system!!! https://www.youtube.com/watch?v=Tq_o7C6KMUA
These interior system liars are all over, just about all states and up in the great white north and they want YOU to call them for a suppppppppppppppppppppppppposed honest estimate, pfffttttttttttttt, watch the hllll out is all I can tell ya, don’t bend over, got that?
