Bullllllllllllllllllllllllllllllllllllllllsht, incompetent! This is what many of these interior basement system salespeople tell homeowners in order to help sway them into thinking their problem is drainage, drain tiles, and they’ll then bllshtt 'em further by telling homeowners they DON’T need to do any exterior waterproofing and that they can install drain tiles/drainage on the INSIDE, all bllllllllllllllllllllllllllllllllllllllllllsht!
http://aquaguardwaterproofing.com/ video at the 1:20 mark…The drainage system originally installed at the build is dysfunctional…
2:45… ‘I think we can supplement the drainage on the exterior with an INTERIOR system and a pump’
See, looolololllllllllllllllllllllllllllll. Friggin nonsense!!! Supplement? Why don’t these salespeople/esti–dorkers supplement my nuggets in their JIBZ!!!
There are EXTERIOR cracks in the basement wall, cracked parging etc and THAT is where the water is first entering the block walls and THAT is WHY there is efflorescence, paint peeling etc!!!
MORE…ONz, moron, moron, moron, mornzzzzzzz.
Incompetent, misleading, misrepresenting the ACTUAL problem and SOLUTION!!!
This homeowner had Aqua-turdz out, see/read what happened…same outfit in video!
This site is dedicated to consumers who were (and will continue to be), victimized as we were.
Similar paint peeling, efflorescence etc on basement wall here…duh!
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing14#5442290582419221154
Click through these photos to see the REAL, existing problems/defects, on the outside of the basement wall and the ONLY solution, which by the way cost $3,200 ish (you will pay MORE for a stoooopid interior basement system that will not stop the water, efflorescence etc!!)
Over and over and over I TRYYYYY to show ya, explain that your problem(s) are NOT this supposed nonsense about ‘drainage’, jesus help them!
Another thing about these interior basement system companies is they’ll LIE, mislead, misrepresent exterior waterproofing and… the COST of exterior waterproofing.
WHY would they do that you ask? loooloolllllllllllllll
Beeeeeee-cause, they don’t do exterior waterproofing or don’t want to and, they make MORE MONEY installing interior systems, much less labor and material-costs involved!
These salespeople aka, ‘estimators’ (is that anything like mastur—b__tors, huh?)…
are either incompetent when they’re in your basements supposedly accessing your problems or, they LIARS… period!
Here’s another similar photo and photo album per that Aqua–turd video
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing46#5480527174029286818
Same house, see where the real problems were and the only means of fixing them…
COST? was close to $1,700.
You’d have paid MORE for any interior basement system and, you’d have the SAME problems, that’s right.
Add to this blllshttt, and as Mr Belrose pointed out on a recent post, many of these companies will also try and BS you, sell you, unneeded carbon fiber straps or wall anchors etc, they sure will. They’ll try and tell you your wall is collapsing and other stuff in order to tack on thousands more, yep.
Something like this, 2 photos… $10,000 for this CRAP
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing54#5516697678082815058
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing54#5516697697450535922
You see the plastic/whatever crap against bottom blocks?
You see how the basement floor was j-hammered aka, interior system?
You see how the WALL/blocks look? (which is why many of these scumball companies COVER, aka HIDE, most or all of the block walls these days)
Ask yourselves, WHY did this homeowner call ME? lolol Think!
They called my azz because it still leaks!
They called me because the supposed LIFETIME guarantee… was NOT!!!
And ANY city inspector who ‘okays’ this kind of crap, installing interior systems, (if and when these chumps pull a permit) when the homeowners actual problems/defects are on the outside of the basement wall, are also incompetent and need to be SUED because, duhhhh, they okayed the permit on the installed system, passed their incompetent inspection, while the homeowners problems/existing defects were NOT fixed!!!~
These dang city inspectors tell us crao like, ‘Oh, we require permits because we want to protect our citizens from the scammers, from contractors who rip off our citizens’, from unscrupulous contractors, etc etc
BLLLLLLLLLLLLLLLLLLLLLLLLLLSHT, that’s blllll-------shttt baby!
How are you city inspectors doing anything for these homeowners who just had an inside system installed that YOU okayed and, that was NOT necessary, did NOT fix the actual problems!!! They just paid $10,000 for an interior system that did NOT do sqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqquat az holes and that YOU, the CITY okayed!!!
This is ABSOLUTE incompetence, negligence on the city’s part, it sure as shttt is!
THIS, in these photos, happens ALL the time…when a city inspector okayed,passes the permit for the installation of this kind of GARBAGE! The homeowner is out $15,000,
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing41
Hence, just because a city may require a permit on any type of waterproofing does not ever mean, you the homeowner can rest peacefully and think, ‘Boy, if the city okayed the inside system companies work, I’m all set’. NON-----fkgggg-SENSE!!!
http://www.youtube.com/watch?v=EYOQ2FeCET8
The Tower/Angel … 'wind is raw, the air is stale, on this cold winters night, Bubba sent alone to tell a tale, from the land of fairy tale basement waterproofing…journey starts in your leaky basement with canzz of Budweisers as my guide…just a light, from the tower!!!
