This guy actually claims, wall anchors are a permanent solution - Get out of Denver!
Nonsense, false claim baby.
So apparently lol homeowner had problems, cracks etc and was told to build a ledge/pony wall against the B wall. $$$
Then more problems occurred and they found this guy who told them they needed wall anchors $$$
Before the ledge wall and before the wall anchors were installed, the basement wall needed exterior waterproofing which would help removed, reduced exterior soil pressure and any possible underground tree roots against wall AND would have waterproofed the existing exterior cracks in B wall.
Now IF there is say, a front porch in this area or drive/patio slabs then sometimes a porch footing can deteriorate, move, settle against the ext of a wall n cause problems, same with driveway or patio slabs.
So the wall isn’t going to get better lol by leaving whatever is causing the cracks, problems on the outside and installing wall anchors or ledge wall does not remove, reduce any weight,pressure OFF-of, acting upon the ext of the wall PLUS, say again lol, there are, have been EXT cracks in the basement wall n so some are telling homeowners it is okay to allow water to continue to penetrate the wall, really? lolol
A ‘permanent solution’ ? Get out of Denver!!
here’s another wall that bowed in, homeowners (seller’s) were told they needed an INT system and sump pump and wall anchors $24,5000, go ahead a nd take a LOOKIE
  1. they created, caused MORE openings for water to enter, see the gaps-holes where they forced rods through wall? uh huh lolllll
  2. they didn’t repair, waterproof ANY of the existing EXT cracks! And they never stopped further water from entering, nope.
  3. they never removed, reduced the lateral SOIL pressure acting upon the wall (all clay) and didn’t remove underground T roots off of wall
‘She pulled out all she had and laid it on the counter’…
'Get out of Denver cause you look just like a commie and you might just be a member
got a wall problem ?..lets poke some holes in it…that should help…
lol exactly Jim, how’s everything in Buckeye land man? Seen D Macy lately?
all good here Partner …have not heard a peep from Dave in a long time…
hopefully he is doing A okay
