Not sure who uses Flir Quick Report. I use it to tune/prep my images, although I don’t use it to publish reports.
The Quick Report tool appears is smarter than it lets on. For instance, there is no option (at least not that I can find) to add an area with a hotspot seeker to your image. However, if the image already has one it will preserve it and what’s more, you can move it, adjust it and even clone it to create more.
Whenever I shoot an electrical panel I’ll set my camera (EX320) measurement mode to area max. When I bring the image into QR I can adjust it as I want. To create a second, third, etc. area max, just hold down the control key and drag it to where you want it. You can then manipulate each area independently.
Another thing that I have discovered with QR is that it can support more pallets than the ones in its menu (apparently the pallet is embedded in the image). This is where Flir’s neat web viewer http://support.flir.se/CustHelp/webViewer/webViewerUL.aspx comes in. You can upload your image, choose a pallet from the large list available on the viewer, then download the image back to your computer and open it in QR. The new pallet will be retained in the image and you can still adjust the span for optimal tuning.
Unfortunately, it appears that you can’t do both in the same image (the web viewer loses the pointer).
I’ve attached a few images which illustrate some of these capabilities. The first image shows multiple area max pointers, while the other three show pallets not available directly in my camera or QR.
Anyone else know of any other tricks to get more out of Quick Report???
