Trumbullite in my cabinet
Originally Posted By: todd wright
How do I know if this is still functional? It’s a Trumbullite. Any info. would be appreciated. There are no references to breaker sizes. Should I pull the cover to explore more? Thanks
[ Image: http://www.nachi.org/bbsystem/usrimages/p/panel.jpg ]
Todd Wright
toddswright@hotmail.com
Originally Posted By: dvalley
Todd,
Welcome to NACHI.
#1) Never heard of such an animal-Trumbullite.
#2) Your pic is ridiculously huge or not a jpg.
#3) Do you own a tic-tracer to answer your question on functionality.
David Valley
MAB Member
http://www.masscertified.com
How does one make the picture smaller?
Todd Wright
Do you have editing software?
Make sure its a .jpg file and make sure it's resolution is somewhere around or under 600 X 800 pixels.
David Valley
MAB Member
Originally Posted By: pdacey
How’s this
http://www.nachi.org/bbsystem/usrimages/p/panel1.jpg
Slainte!
Patrick Dacey
swi@satx.rr.com
TREC # 6636
www.southwestinspections.com
ok, i think i learned somethin. try this.
[ Image: http://www.nachi.org/bbsystem/usrimages/n/new_panel.JPG ]
Todd Wright
Originally Posted By: Brian A. Goodman
Wow, I’ve never so much as heard of that one.
It depends on what you mean by functional. You can determine if power is getting through it with a voltage meter or detector. You can find out if it actually disconnects the same way, but operating something that old is risky (may well be the last time). There are also ways to determine if they really trip or not, but I sure as hell wouldn't try any of that.
I would cautiously pull the cover and check it out, but I'd recommend replacement no matter what I found. That equipment is obsolete and apt to fail at any time without warning. It's very unlikely it would trip if it needed to, IMHO.
Originally Posted By: cbuell
Quote:
Trumbull Electric Mfg. 1920 Catalogue
is available on ebay. Could give you an idea of how old the thing is. I would have to agree that it is most likely long past its expected/useful life!
It is easier to change direction than it is to forget where one has been.
The house is 1950 and has been remodeled with a new main panel on the outside but still has some old wiring. I’m trying to figure out if it’s functional so I’ll buy some type of volt meter today.
Todd Wright
Todd,
Pull the cover off, wet your finger and touch the exposed wires. That'll give you your answer.![](upload://mdBgTaj9XMffHehtOaWA12aodfb.gif)
David Valley
MAB Member
Originally Posted By: mpatton
Todd,
No disrespect intended, "CALL an ELECTRICIAN".
I appreciate your desire to learn but be safe at the same time.
An experienced electrician will also be able to make recommendations and resolve issues for you that you will not find in most modern electrical books.
Michael Patton
AA Home Inspection
Serving Northern KY & Greater Cincinnati OH
AA@AAHomeInspection.net
www.AAHomeInspection.net
Originally Posted By: dedwards
Todd,
For things like that I carry of couple of voltage “sniffers”. Get a fix on whether or not it is still carrying voltage, then refer it to an electrician. When you get into the troubleshooting arena you step out of the realm of SOP and are over into the JOB of a specialist. SOP keeps our butts out of trouble if we follow them. When you step out of the box you open yourself up. Just some friendly advice. Best to leave the deep analysis to the experts in the respective fields.
What is SOP?
Todd Wright
Originally Posted By: jhagarty
http://www.nachi.org/sop.htm
Joseph Hagarty
HouseMaster / Main Line, PA
joseph.hagarty@housemaster.com
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
