Truss Top Chord Cut - Normal?
IMG_8141
I have never seen this before and I was hoping someone could shed some light as to why a roof would be designed this way as it was clearly an intentional and repeated decision.
What is the name of this type of structure and what is its purpose?
I can only guess that this is not the main structural member and is only holding on the roof material.
IMG_8146
IMG_8143
Thanks,
Jon
This type of roof framing is used on modular homes. It is not a typical truss system. The hinges are there for erecting the roof after setting the module in place. You should have seen two ridge plates and two center beams at the attic floor.
A bolt securing the two ridge plates is visible in the second picture
Yup, hinged truss.
images3
images2
images
14597
Dennis and Stephen got it.
