Thought I would post some pictures of a job I’m working on. Several projects at the same time but these pictures are of the underpinning of a foundation. The pins are just like auger bits and get screwed into the ground, one on top of the other until they hit solid ground. In this case 60 feet deep. Then the brackets are bolted to the footing.
The problem with this house is a pond on the property next door overflowed and damaged the foundation.
The well on this property has been compromised so we will need to bore under the road to connect to the city water supply across the street.
Other projects going on are new rubber roof, re-point the chimney, repair sag in ceiling frame, build a new deck and lay down some vinyl flooring.
