Originally Posted By: ckratzer
David I too install vinyl siding and pvc coated aluminum wrap for more years than I care to mention.
It is almost impossible to wrap over the facia edge at the eaves simply because roofing nails will prevent it.Most homes are roofed before the siding installers get there.
While drip edge is not required you will see it in better roofing applications.
The alum. wrap is indeed tucked into the "J" channel which in this particular application would only further trap water if it does leak behind the wrap.Drip edge would prevent this if it had been installed over the wrap.Style "D" edge would be excellent as it protrudes about 5/8 over the trim.[/quote]
