Warren MI, someone tried playing with the crack on the inside and, someone dug the exterior in this area but ONLY applied tar and backfilled with the same clay. All along it just needed to be waterproofed and backfilled correctly on the outside…
1:10—1:30, see the ‘other’ exterior OPENINGS? Huh? :mrgreen:
Injections done from the inside do NOT seal/repair ANY of these so, water can/will still get in because these OTHER exterior openings were not identified and repaired.
1:40 deteriorating mortar joints, only going to get worse.
Raising the grade and not these sealing the bricks and joints is a mistake.
Another poured wall crack etc… homeowner had Everdry over for an estimate and duhhhh, how much did these twinks want? Yeah shtt sure, real professional.
Photo of underground tree root caused cracks, subsequent leaks/seepage in basement
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing09#5442183457360199010
Root now removed…
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing09#5442183496301296754
No interior basement system and sump pump removes roots etc that cause many cracks/leaks, duh!
