Please take a moment and vote for your best Defect Picture for this Month.
Thanks
#1
They paved around this heatpump, go figure…
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/63672d1364681496t-now-accepting-defect-pictures-april-pic-014.jpg
#2
Rafters? We don’t need no stinking rafters. (or clearance)
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/63673d1364682403t-now-accepting-defect-pictures-april-p3270188.jpg
#3
4x4 floor joists cut and spliced with 2x4’s with a gap in between
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/63676d1364698294t-now-accepting-defect-pictures-april-sam_9528.jpg http://www.nachi.org/forum/attachments/f11/63677d1364698339t-now-accepting-defect-pictures-april-sam_9523.jpg
#4
“There used to be a moisture problem… Wait!, you’re going under there?”
Not that unusual, it was just funny the way the guy said it.
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/63679d1364699779t-now-accepting-defect-pictures-april-pb210095.jpg http://www.nachi.org/forum/attachments/f11/63680d1364699822t-now-accepting-defect-pictures-april-pb210096.jpg
#5
Make sure you walk through the middle of the kitchen - the house might tip over.
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/63681d1364703042t-now-accepting-defect-pictures-april-picture.jpg
#6
Everyone knows for proper support you need Campbell Soup Chunky style
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/63693d1364783951t-now-accepting-defect-pictures-april-sam_9491.jpg
#7
What do you mean the gas meters is a bad location?
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/63705d1364821829t-now-accepting-defect-pictures-april-p3270003.jpg
#8
I’m not sure if this structure is meant to support a sod farm…
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/63707d1364829325t-now-accepting-defect-pictures-april-mossroof.jpg
#9
**“Uh, Mr. Inspectorman, we’ve had a slight set-back since you were here last”! **
(And no, Mr. Inspectorman was not advised of any “change orders” prior to arrival)!
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/63708d1364830570t-now-accepting-defect-pictures-april-dsci0009.jpg http://www.nachi.org/forum/attachments/f11/63709d1364830645t-now-accepting-defect-pictures-april-dsci0004.jpg
#10
Dont you think we would see stains in the ceiling if the roof leaked?
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/63714d1364841164t-now-accepting-defect-pictures-april-drippy.jpg
#11
Homeowner… I don’t know how it happened but the whole dam roof cracked
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/63734d1364855038t-now-accepting-defect-pictures-april-cooley-052-small-.jpg
#12
Yes, I lifted the rug. But only because I felt a slight depression in the floor.
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/63925d1365245143t-now-accepting-defect-pictures-april-img_0151.jpg http://www.nachi.org/forum/attachments/f11/63926d1365245161t-now-accepting-defect-pictures-april-img_0152.jpg
#13
there is a main electrical shut off under this waterfall
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/63958d1365366889t-now-accepting-defect-pictures-april-cellphone-11-15-12-443.jpg http://www.nachi.org/forum/attachments/f11/63959d1365367879t-now-accepting-defect-pictures-april-cellphone-11-15-12-444.jpg
#14
They were going to install a big beautiful picture window, so they cut out the framing, left the brick in place & were ready to receive the window.
When the window arrived & it was the wrong size. So they just framed up the hole & stuck a clock on the brick, put an awesome antique train in at the bottom & called it a day.
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/63941d1365295010t-now-accepting-defect-pictures-april-p4020053.jpg
#15
Sure wish I had a better pic. This plastic tube ran from the condensate drainage pump up to and friction fit on to a half inch cpvc pipe. that cpvc pipe was jammed into another plastic tube and attached to copper tubing and then they even put in a small trap before heading back up to another connector about a couple inches long and the other end was fit over a threaded six inch nipple which was screwed into a drilled and threaded hole in the existing drain pipe. I thought it was a rather clever mickey mouse setup and since it was drainage and obviously low pressure, I did not make much of a stink about it but pointed it out as a rather unorthadox setup
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/64024d1365562659t-now-accepting-defect-pictures-april-drain.jpg
#16
A true can light. Is this IC rated?
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/64107d1365721346t-now-accepting-defect-pictures-april-imgp1164.jpg
#17
The new weep hole sprinkler system
Attached Thumbnailshttp://www.nachi.org/forum/attachments/f11/64150d1365856104t-now-accepting-defect-pictures-april-036.jpg
