Wall Construction?
Originally Posted By: Kevin Blackwell
I am searching for the answer to what is the top portion of the wall called
That stick out above wall framing is it calls (partition wall or curtain wall?
Please explain.
Thx Kevin from Houston,TX
are you referring to a knee wall? Not sure what your are referring to??
No Kevin Its’ not a knee wall or cripple wall.
I’ll try too explain it better.
The interior wall and ceiling is finish,Then you box in another 3 foot wall on top of that without a ceiling.So it look like a fort you could stand on an look over the wall.
What is the name of that 3 foot section of wall?
Thx Kevin from Houston.
Originally Posted By: jwortham
It’s called a parapet wall. Usually seen on flat roofs.
Jeff,
Thanks that’s what I was searching for now I can look it up.
