I got a call from a client, for a home inspection, one of his main concerns was to check on a wall that was leaning towards the house (im thinking foundation) and causeing water damage. He was informed that it had been fixed. Has anyone had a similar situation happen ?
Wall anchors like these may/might give a lil support to inside wall ‘where they were applied’…doesnt mean poured/block wall still wont bow in further afterwards, especially if the CAUSE hasnt been diagnosed n repaired/removed etc. The cause is often-not always, lateral soil pressure and or roots and or porch footing etc. If they/contractor put wall anchors up as in pic it doesnt mean they diagnosed/removed the CAUSE and they didnt waterproof exterior of wall, still leaking as ya.
Ya might see beams or carbon fiber straps, again, does NOT mean contractor removed the cause and certainly doesn`t mean they repaired/waterproofed the leak/cracks etc.
Walls were recently painted,see efflorescence,mold-mildew on walls. That crap is still there and will continue to be there because the inside system that was installed does not stop/prevent water from entering the cracks on exterior of block walls.Nor does it stop/prevent insects from entering the same cracks.
