This residence is in Southern Calif…
Its a Water Heater installed in the basement.
The overflow pipe is discharging to the floor…( cement floor )
is that ok?
Vent pipe has about 1/2 clearance from the drywall…does it need
a heat collar?
David
is that ok?
a heat collar?
David
Looks to me like exhaust is running down hill not allowed.
Sorry I forgot the ( [FONT=Verdana][size=2]The overflow pipe is discharging to the floor…( cement floor ) is that ok? ) The answer is yes its OK [/size][/FONT]
Discharging to the floor is fine.
6" to combustibles for single exhaust vent is required. Call it out and move on.
Thanks for the advice…
I don’t see a sediment trap or cold water shut-off in that setup either.
Looks like a Rheem unit which requires sediment installation.
C vent piping requires 6 inches from combustables, some inspectors might concider the paper from the drywall to be combustable o be on the safe side cut back the drywall 6 inches. The relief vale piping to the floor is correct providing there is aleast 6 inchesa off the floor
I don’t believe that tape is allowed on the joints…3 screws per joint … so many things wrong …like everyone has said report and move on!
