Water line and outlet
I have a water line with angle stop sitting in front of and outlet under the sink. Any thoughts?
As long as it is gfci protected theres nothing abnormal about that, most of the houses i electrically trim out have lines blocking the undersink outlet making it almost impossible to get the air switch Installed for the disposal.
The photo is from a bad angle. Can the plug be removed? if so, no problem other than whoever installed the PEX mess clearly didn’t care.
As long as the box is accessible then there is no electrical issue.
Thank you Robert.
