tspargo
(Tim Spargo, CMI)
March 29, 2011, 5:00pm
What’s the highest (or lowest) pressure you’ve measured at a Home Inspection?
I’ve had lots near 140-150 or so… 170 psi measured yesterday in Palmdale is definitely one of the higher numbers I can remember.
I’ve measured about 20 psi from wells as well.
You didn’t need a gauge to know there was something outta whack.
rcooke
(Roy D. Cooke, Sr)
March 29, 2011, 6:48pm
2
My home 185 You did not need soap in the shower off comes a layer of skin .
I reduced it down to 45 lbs much nicer .
jharrison
(John Harrison, CMI)
March 29, 2011, 6:58pm
3
Highest pressure ive come across so far is 90psi
Lowest I’ve has was 35psi on a well. Home owners knew of the problem the had a new pressure regulator ready to install laying next to the incoming line.
Maximum water pressure should not exceed 80psi.
jszczesny
(James Szczesny, Certified Master Inspector WSLHI #711 CMI)
March 29, 2011, 9:06pm
5
Gotta be sure your gauge isn’t wacked also, I got high readings once, didn’t catch it for a couple houses. oops
jpope
(Jeffrey Pope, CMI, CHI, CPI, ICC)
March 30, 2011, 2:47pm
6
My street pressure is 180 psi. Much of Santa Clarita has ultra-high pressure. Regulators don’t generally last more than 4 or 5 years in our area.
