How do you handle docks,davits and seawalls. how about boathouses.
extra charge…disclaim… ancillary…beyond sop…
any verbage out there
thanx in advance
thanx in advance
Note general condition of seawall cap and tie-back connections. Treat dock like a deck inspection. Check electrical for GFCI protection. General condition of davits or lift, but don’t operate, especially if a boat is on it. Doesn’t take long so I include it.
No, yes, yes, yes, and recommend that before hoisting boat consulting a licensed lift contractor…As with all sea walls, we recommend consulting a licensed engineer famialar with…
I run into alot of this in my area. I don’t charge to inspect the dock for obvious issues. I always recommend the seek the correct licensed specialist experience with the seawall/lift/etc…
It are job to spot problems. It’s also our job to point them in right direction when we are outside our area of expertise. Docks, lifts, and seawalls are tricky items.
I do look at docks, seawalls, lifts, and ramps. I can only see what I can see(we do not look underwater). If you need more answers, hire a licensed marine contractor.
thanx guys
